TwinTurbo.NET: Nissan 300ZX forum - replaced engine & alt. harness, have warning lights
Subject replaced engine & alt. harness, have warning lights
Posted by someotherguy on September 18, 2013 at 11:22 PM
  This message has been viewed 153 times.
Message I have the "light" and "brake" dash warning lights on, and the "charge" warning light on dimly. All my brake lights are working. Disconnecting the brake reservoir connector and / or shorting it with a jumper changes nothing. One of its pins is continuous with ground, the other is also only if the handbrake is pulled. Otherwise it has 11.8 volts when key is in on position. Car runs fine. Any suggestions appreciated.
